Grundig TK125 Transport Belts Replacement
  1. Grundig TK125 Transport Belts Replacement, Transport Belts: step 1, image 1 of 2 Grundig TK125 Transport Belts Replacement, Transport Belts: step 1, image 2 of 2
    • I have ordered a new belt set on aliepxress, to be continued once i received them
  2. Grundig TK125 Transport Belts Replacement: step 2, image 1 of 1
    • These are the 3 belts needed (if all) for the TK125, the biggest is needed for the flywheel, the midsize of for the drive and the smallest of for the counter.
  3. Grundig TK125 Transport Belts Replacement: step 3, image 1 of 2 Grundig TK125 Transport Belts Replacement: step 3, image 2 of 2
    • Now remove the bottom and the top covers so you can reach both sides of the recorder
  4. Grundig TK125 Transport Belts Replacement: step 4, image 1 of 2 Grundig TK125 Transport Belts Replacement: step 4, image 2 of 2
    • Remove the flywheel axle restplate, here is your opening to replace both the belts
  5. Grundig TK125 Transport Belts Replacement: step 5, image 1 of 1
    • first you place the large flywheel belt, then you place the midsize belt for the drive
  6. Grundig TK125 Transport Belts Replacement: step 6, image 1 of 1
    • this is the small belt for the counter
Joenymus
148 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 15
All Time: 34
