Guide 1: XIAOMI Air Fryer top lids disassembly
  1. Guide 1: XIAOMI Air Fryer top lids disassembly, Guide 1: XIAOMI Air Fryer top lids disassembly: step 1, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly, Guide 1: XIAOMI Air Fryer top lids disassembly: step 1, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly, Guide 1: XIAOMI Air Fryer top lids disassembly: step 1, image 3 of 3
    • Disassembly of the screwless top cover and second cover on the top of the XIAOMI Air Fryer, many other manufacturers use a similar system.
  2. Guide 1: XIAOMI Air Fryer top lids disassembly: step 2, image 1 of 1
    • Remove the cooking basket.
  3. Guide 1: XIAOMI Air Fryer top lids disassembly: step 3, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 3, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 3, image 3 of 3
  4. Guide 1: XIAOMI Air Fryer top lids disassembly: step 4, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 4, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 4, image 3 of 3
    • Close up of the clips where the top cover clamps to the main body.
    • Steps 11 and 12 show why the lid can't be dismounted without breaking the clips.
  5. Guide 1: XIAOMI Air Fryer top lids disassembly: step 5, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 5, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 5, image 3 of 3
    • Taking apart the second top cover: take out 6 rubber lids around the outer edge to uncover 6 screws.
  6. Guide 1: XIAOMI Air Fryer top lids disassembly: step 6, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 6, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 6, image 3 of 3
    • With a prying tool or a needle it is easy to remove the rubber plugs.
  7. Guide 1: XIAOMI Air Fryer top lids disassembly: step 7, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 7, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 7, image 3 of 3
    • Remove the 6 screws with the help of a flathead screwdriver.
  8. Guide 1: XIAOMI Air Fryer top lids disassembly: step 8, image 1 of 2 Guide 1: XIAOMI Air Fryer top lids disassembly: step 8, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
  9. Guide 1: XIAOMI Air Fryer top lids disassembly: step 9, image 1 of 2 Guide 1: XIAOMI Air Fryer top lids disassembly: step 9, image 2 of 2
    • Remove the 4 inner screws.
  10. Guide 1: XIAOMI Air Fryer top lids disassembly: step 10, image 1 of 2 Guide 1: XIAOMI Air Fryer top lids disassembly: step 10, image 2 of 2
    • Lift the cover.
  11. Guide 1: XIAOMI Air Fryer top lids disassembly: step 11, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 11, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 11, image 3 of 3
    • Here you can see in detail why the clips cannot be removed without breaking them, the space between the clip and the connecting cover does not allow the clip any movement and thus it cannot be pushed to clear the hook once the top cover is inserted, rendering it impossible to remove the top lid without breaking the clips.
  12. Guide 1: XIAOMI Air Fryer top lids disassembly: step 12, image 1 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 12, image 2 of 3 Guide 1: XIAOMI Air Fryer top lids disassembly: step 12, image 3 of 3
    • Once both lids are removed the remains of the broken clips will be scattered around the inside of the Air Fryer. Remove them taking special care and be sure to check the fan (3º Picture) as any plastic piece left there will melt, leaving a burnt plastic smell.
    • This is the end of the 1º Guide on the Air Fryers disassembly. Other guides on this model: AIR FRYER XIAOMI
To reassemble your device, follow these instructions in inverse order.
2 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
68,860 Reputation
220 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,697 Guides authored
One Comment
Donde se puede comprar estas piezas gracias
Jose Manuel Muñoz - Reply
Past 24 Hours: 11
Past 7 Days: 80
Past 30 Days: 308
All Time: 2,432
