Disassembly of the screwless top cover and second cover on the top of the XIAOMI Air Fryer, many other manufacturers use a similar system.
TOP COVER: due to the part being manufactured to prevent it from being opened, It CANNOT be taken apart without breaking the 5 clips.
Use side to side pressure and lever action to break the clips.
Video In which I show this step in detail: https://www.youtube.com/watch?v=g7nbo_C1...
XIAOMIs video on full dissasembly: https://www.youtube.com/watch?v=zi_X43WH...
Tool used on this step:Magnetic Project Mat$19.95
Its of much use in this disassembly to own the Magnetic Project Mat
Here you can see in detail why the clips cannot be removed without breaking them, the space between the clip and the connecting cover does not allow the clip any movement and thus it cannot be pushed to clear the hook once the top cover is inserted, rendering it impossible to remove the top lid without breaking the clips.
Once both lids are removed the remains of the broken clips will be scattered around the inside of the Air Fryer. Remove them taking special care and be sure to check the fan (3º Picture) as any plastic piece left there will melt, leaving a burnt plastic smell.
This is the end of the 1º Guide on the Air Fryers disassembly. Other guides on this model: AIR FRYER XIAOMI
donde se puede comprar la tapa superior y la de dentro
Lo siento Manuel no lo se, creo que no se venden, encuentras repuestos de componentes pero de carcasas y tapas es una cosa que raramente se cambia por lo que el fabricante no las produce para venta publico. Yo al menos rebuscando no he encontrado el despiece.
To reassemble your device, follow these instructions in inverse order.
2 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
