This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
H4D: Cleaning throttle body without dismantling
  1. H4D: Cleaning throttle body without dismantling, Accessing the engine hood: step 1, image 1 of 1
    • Open the trunk.
    • Put aside the trunk carpets.
  2. H4D: Cleaning throttle body without dismantling, Acessing the engine compartment: step 2, image 1 of 1
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. H4D: Cleaning throttle body without dismantling, Remove the air filter housing: step 3, image 1 of 2 H4D: Cleaning throttle body without dismantling, Remove the air filter housing: step 3, image 2 of 2
    • Using a screwdriver, loosen the two Torx T25 screws on the air filter cover.
    • Remove the cover by moving it forward and then lifting it.
  4. H4D: Cleaning throttle body without dismantling, Clear the air duct: step 4, image 1 of 2 H4D: Cleaning throttle body without dismantling, Clear the air duct: step 4, image 2 of 2
    • Disconnect the oil vapour breather.
    • Loosen the hose clamp on the pipe leading to the throttle body using a flathead screwdriver.
    • Remove the pipe and airbox cover. Set the filter aside if it is to be used again later.
  5. H4D: Cleaning throttle body without dismantling, Cleaning the throttle valve: step 5, image 1 of 3 H4D: Cleaning throttle body without dismantling, Cleaning the throttle valve: step 5, image 2 of 3 H4D: Cleaning throttle body without dismantling, Cleaning the throttle valve: step 5, image 3 of 3
    • Spray brake or contact cleaner on the throttle and use a soaked paper towel to clean it until the body and edges are clean.
    • It is recommended to wear gloves while handling the break cleaner.
    • Allow to dry for a few minutes before refitting the airbox.
    • When the ignition is switched on, the throttle valve defaults to the idle position, but it can be opened fully by holding the accelerator pedal to the stop.
    • If the accelerator pedal is released, even slightly, the throttle will close, risking cuts to fingers and damage to the gearbox motor!
    • Replace the pipe as far as it will go.
    • Tighten the clamp screw with a flathead screwdriver while holding the pipe in its correct position.
    • Reinstall the air filter.
    • Replace the cover by sliding it towards the notches.
    • Re-tighten the two Torx T25 screws while maintaining slight pressure on the cover.
    • The first restart after cleaning is likely to fail and/or require many, many revolutions of the starter motor, even if the engine is warm!
    • Depending on the initial level of contamination, the ECU needs to reset itself to a completely different idle position from the one it recorded just before. It may take a few moments to recalibrate itself automatically.
    • Once the engine is stable, carry out a test drive. The results presented below are ideal and there is no guarantee that all of them will be achieved.
    • Engine behaviour, particularly at low revs and idling, may become smoother. The idle speed may drop more quickly and become more stable.
    • Vibrations are reduced when restarting at stop signs, red lights and when maneuvering on wet/icy roads.
    • Better engine response when the clutch is re-applied and during restart: beneficial for heel-toe shifting.
    • This operation reduces clutch wear during any operations involving the clutch.
Congratulations ! You have just cleaned your throttle body !
Special thanks to these translators:
fr en
92%
These translators are helping us fix the world! Want to contribute?
Start translating ›
AntonioBiscuit
6,314 Reputation
43 Guides authored
2 Comments
Ce tuto ne fonctionne pas pour le Tce90. Le boîtier papillon n'est pas accessible.
Bibard - Reply
En effet vous avez raison ! Je vais préciser que ce tutoriel est uniquement applicable au moteur H4D.
AntonioBiscuit -
Past 24 Hours: 20
Past 7 Days: 123
Past 30 Days: 567
All Time: 8,697
