HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup)
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup), Bacterial Filter: step 1, image 1 of 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): step 2, image 1 of 1
    • Disconnect used/contaminated INSPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the inspiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the inspiratory limb.
    • The used/contaminated bacterial filter should now be removed from the inspiratory port.
    • In reassembly, a new/non-contaminated INSPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  3. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): step 3, image 1 of 1
    • Disconnect used/contaminated EXPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the expiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the expiratory limb.
    • The used/contaminated bacterial filter should now be removed from the expiratory port.
    • In reassembly, a new/non-contaminated EXPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  4. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): step 4, image 1 of 1
    • Your two new bacterial filters should now be installed in their respective inspiratory and expiratory ports.
    • After completing all steps, the end result should look like this:
Luisa Chiu
205 Reputation
2 Guides authored
Cal Poly, Team S7-G11, Paton Spring 2020 Member of Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 394
