HASEE Z6-SL7D1 RAM Replacement
  1. HASEE Z6-SL7D1 RAM Replacement, RAM: step 1, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement, RAM: step 1, image 2 of 2
    • Flip your laptop over so the bottom is facing up and set it on a flat surface.
    • Use a Phillips #0 screwdriver to remove the two 6 mm screws that secure the battery.
  2. HASEE Z6-SL7D1 RAM Replacement: step 2, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement: step 2, image 2 of 2
    • Gently lift the battery from the laptop.
  3. HASEE Z6-SL7D1 RAM Replacement: step 3, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to remove fourteen 6 mm screws from the back panel.
  4. HASEE Z6-SL7D1 RAM Replacement: step 4, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement: step 4, image 2 of 2
    • If your laptop is equipped with an optical drive, carefully slide it out.
    • Alternatively, if the optical drive bay houses a hard drive tray, remove the tray by unscrewing any securing screws and gently pulling it out.
  5. HASEE Z6-SL7D1 RAM Replacement: step 5, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement: step 5, image 2 of 2
    • Carefully slide a plastic spudger or opening tool along the edges of the back panel.
    • Gradually lift the panel away from the laptop chassis, ensuring not to force it and risking damage to internal components.
  6. HASEE Z6-SL7D1 RAM Replacement: step 6, image 1 of 3 HASEE Z6-SL7D1 RAM Replacement: step 6, image 2 of 3 HASEE Z6-SL7D1 RAM Replacement: step 6, image 3 of 3
    • Use your fingers or a spudger to gently press the clips on the sides of the SO-DIMM slots outward to release the memory modules.
    • The RAM sticks will pop out at about a 45-degree angle.
    • Once the RAM sticks disengage, carefully slide them out of the slot at the same angle.
  7. HASEE Z6-SL7D1 RAM Replacement: step 7, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement: step 7, image 2 of 2
    • When installing new memory sticks, align them with the SO-DIMM slots at the same angle and gently press them downward.
    • You will hear a click, indicating that it is securely in place.
  8. HASEE Z6-SL7D1 RAM Replacement: step 8, image 1 of 2 HASEE Z6-SL7D1 RAM Replacement: step 8, image 2 of 2
    • Replace the back case.
    • Insert the optical drive back into its designated slot.
    • Replace the battery.
    • Use a Phillips #0 screwdriver to secure the fourteen 6 mm screws on the back case.
    • Use a Phillips #0 screwdriver to replace the two 6 mm screws that secure the battery.
2 other people completed this guide.
Jiayi Liu
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 123
All Time: 1,714
