HDD Replacement HP Laptop 15-g053nl
  1. HDD Replacement HP Laptop 15-g053nl, HDD: step 1, image 1 of 3 HDD Replacement HP Laptop 15-g053nl, HDD: step 1, image 2 of 3 HDD Replacement HP Laptop 15-g053nl, HDD: step 1, image 3 of 3
    • Remove the battery pack
    • Remove the two rubber pads on the display side
    • Remove 11 Philips screws framed in red
    • Remove DVD Drive
    • Remove the screw (maybe 2 screws) framed in green
  2. HDD Replacement HP Laptop 15-g053nl: step 2, image 1 of 3 HDD Replacement HP Laptop 15-g053nl: step 2, image 2 of 3 HDD Replacement HP Laptop 15-g053nl: step 2, image 3 of 3
    • Insert a thin tool or a flat screwdriver in the little slits on the upper side of the keyboard lift up, to unhook the locking clips.
    • Lift up the keyboard, being careful about the flat cable.
    • Lift up the connector and disconnect the flat removing the battery.
  3. HDD Replacement HP Laptop 15-g053nl: step 3, image 1 of 2 HDD Replacement HP Laptop 15-g053nl: step 3, image 2 of 2
    • Remove the 3 screws marked in red
    • Unhook the 2 connector and unplug the flat cables
  4. HDD Replacement HP Laptop 15-g053nl: step 4, image 1 of 2 HDD Replacement HP Laptop 15-g053nl: step 4, image 2 of 2
    Tool used on this step:
    Jimmy
    $7.95
    Buy
    • With a thin instrument, release the clips around the perimeter retaining the top cover, leaving the rear shell containing the motherboard etc. (The iFixit Jimmy is ideal for this.)
    • Remove the top cover, giving access to the hard disk.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,447 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 42
All Time: 1,115
