HIFIMAN Sundara Headstrap Replacement
    • This step is necessarily destructive, and with careful application of the cutting pliers, no damage will be done to the headphones. Make sure to remove both fasteners.
    • The headstrap-headband interface is the piece of plastic which the headstrap itself adheres and whereby it attaches or interfaces with the headband. This part will be referred to as Interface for brevity from here on.
    • Remove the old headstrap from the headband as shown by detaching the Interfaces from the headband.
    • A metal strip is present inside both of the Interfaces. Make sure to retrieve them and set them aside in a salient location.
    • Remove the drivers (speakers) as shown.
    • Insert the new headstrap as shown into the headband by inserting the Interface into the headband, but do not yet press the Interface into the headband.
    • Don't forget to re-insert the metal strips mentioned in Step 2 here as shown in the video.
    • As the design of the headband is ambipolar, which side of it is designated as the left or right side does not matter.
    • Before inserting the drivers back into the headband, make sure the metal place holders that secure driver length are correctly inserted at the start of the interface. The small spheroidal convex indentation of this piece should have the convex (protruding) side facing outwards which will interface with the concave indentations on the drivers.
    • To verify that the metal placeholders are properly installed: if the inner part of the Interface that attaches the headstrap to the headband can be closed with ease (must be actively held together), and the driver being inserted correctly locks in place, the metal place holders have been correctly installed and you may proceed onwards.
    • Make sure the metal fasteners have the correct polarity, either L or R, facing on the inside.
    • After ensuring that the metal fasteners are facing the correct direction, slide the drivers back into the headband and firmly press closed the Interface as shown in the video.
    • Firmly push the metal fastener upwards to permanently secure the Interface to the headstrap as shown. No adhesive is required.
    • Make sure to apply equal amounts of force as you push the fastener onto the Interface.
Headstrap replacement is complete.
Andrew
121 Reputation
1 Guide authored
15 Guide Comments
you absolutely do not need to cut the metal fastener in step 1. just pry it downward carefully with a flathead screwdriver and it comes free.
never perfect - Reply Share
Thanks for this tip, had to deal with a loose headstrap and it is very easy to just pry it with a screwdriver. You don't even dent it at all if you're careful.
Tomáš Renner - Share
Where do you buy the headstrap?
Ryan Ferguson - Share
This assumes you can get past the heavy glue. The videos are from the factory itself apparently in my parts and repair request. Questionable use of copyrighted content, yes, but I had let them know, and they haven't done anything, so /shrug.
Andrew - Share
@ryanfergus24861 Simply contact HiFiMan themselves and request parts. That's what I did.
Andrew - Share
Past 24 Hours: 8
Past 7 Days: 62
Past 30 Days: 238
All Time: 12,338
