HKC P771A Camera Replacement
  1. HKC P771A Camera Replacement, Camera: step 1, image 1 of 3 HKC P771A Camera Replacement, Camera: step 1, image 2 of 3 HKC P771A Camera Replacement, Camera: step 1, image 3 of 3
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Camera Replacement: step 2, image 1 of 2 HKC P771A Camera Replacement: step 2, image 2 of 2
    • Remove yellow tape around the edges of the battery
    • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
  3. HKC P771A Camera Replacement: step 3, image 1 of 3 HKC P771A Camera Replacement: step 3, image 2 of 3 HKC P771A Camera Replacement: step 3, image 3 of 3
    • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
  4. HKC P771A Camera Replacement: step 4, image 1 of 1
    • Remove yellow tape that is securing the camera wires
  5. HKC P771A Camera Replacement: step 5, image 1 of 2 HKC P771A Camera Replacement: step 5, image 2 of 2
    • Remove silver foil from the back of the camera using the blue opening tool
  6. HKC P771A Camera Replacement: step 6, image 1 of 1
    • Lift the bronze, L-shaped ribbon
    • The camera is attached to the end of this ribbon so it will move with it
  7. HKC P771A Camera Replacement: step 7, image 1 of 1
    • Flip up the black bar located on the motherboard
    • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
  8. HKC P771A Camera Replacement: step 8, image 1 of 1
    • Remove the bronze, L-shaped ribbon from inside the black bar
  9. HKC P771A Camera Replacement: step 9, image 1 of 1
    • Your camera is now removed from the tablet
Sara Hill
101 Reputation
2 Guides authored
Ohio State, Team 2-3, Garvin Fall 2015 Member of Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 170
