HMD Fusion Back Cover Replacement
  1. HMD Fusion Back Cover Replacement, Remove the SIM card tray: step 1, image 1 of 3 HMD Fusion Back Cover Replacement, Remove the SIM card tray: step 1, image 2 of 3 HMD Fusion Back Cover Replacement, Remove the SIM card tray: step 1, image 3 of 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
  2. HMD Fusion Back Cover Replacement, Remove the back cover screws: step 2, image 1 of 3 HMD Fusion Back Cover Replacement, Remove the back cover screws: step 2, image 2 of 3 HMD Fusion Back Cover Replacement, Remove the back cover screws: step 2, image 3 of 3
    • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
    • Use your fingernails, or angled tweezers, to remove any stuck screws.
    • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
  3. HMD Fusion Back Cover Replacement: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • During the next four steps, the remaining back cover screws might fall out unexpectedly.
    • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
  4. HMD Fusion Back Cover Replacement, Unclip the back cover: step 4, image 1 of 2 HMD Fusion Back Cover Replacement, Unclip the back cover: step 4, image 2 of 2
    • Flip your phone over so the screen is facing up.
    • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
  5. HMD Fusion Back Cover Replacement: step 5, image 1 of 3 HMD Fusion Back Cover Replacement: step 5, image 2 of 3 HMD Fusion Back Cover Replacement: step 5, image 3 of 3
    • Slide the opening pick along the left edge to begin unclipping the back cover.
  6. HMD Fusion Back Cover Replacement: step 6, image 1 of 3 HMD Fusion Back Cover Replacement: step 6, image 2 of 3 HMD Fusion Back Cover Replacement: step 6, image 3 of 3
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
  7. HMD Fusion Back Cover Replacement: step 7, image 1 of 3 HMD Fusion Back Cover Replacement: step 7, image 2 of 3 HMD Fusion Back Cover Replacement: step 7, image 3 of 3
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
  8. HMD Fusion Back Cover Replacement, Disconnect the battery: step 8, image 1 of 3 HMD Fusion Back Cover Replacement, Disconnect the battery: step 8, image 2 of 3 HMD Fusion Back Cover Replacement, Disconnect the battery: step 8, image 3 of 3
  9. HMD Fusion Back Cover Replacement, Disconnect the power button: step 9, image 1 of 3 HMD Fusion Back Cover Replacement, Disconnect the power button: step 9, image 2 of 3 HMD Fusion Back Cover Replacement, Disconnect the power button: step 9, image 3 of 3
    • Use a spudger to pry up and disconnect the power button press connector.
    • Remove the back cover.
  10. HMD Fusion Back Cover Replacement, Remove the power button: step 10, image 1 of 3 HMD Fusion Back Cover Replacement, Remove the power button: step 10, image 2 of 3 HMD Fusion Back Cover Replacement, Remove the power button: step 10, image 3 of 3
    • If your replacement back cover doesn't come with a power button pre-installed, follow the next two steps to remove and transfer it.
    • Use the tip of a spudger to lift the two rubber arms securing the power button out of their slots in the back cover.
  11. HMD Fusion Back Cover Replacement: step 11, image 1 of 1
    • Lift the power button out of the recess in the back cover and remove it.
Alex Diaz-Kokaisl
215,410 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 1,601
