Introduction
Follow this guide to replace the vibration motor in your HMD Pulse Pro smartphone.
If the vibrations coming from your phone feels rattly or are intermittent, you might need to replace the vibration motor.
Unplug all cables from your phone and completely power it down.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
Use a Phillips screwdriver to remove the seven 3.6 mm‑long screws securing the charging board cover.
Use the point of a spudger to pry up and disconnect the charging board cable press connector on the top edge of the board.
Slide one arm of a pair of tweezers under the metal neck of the black antenna cable's connector head, near the center of the board.
Lift straight up to disconnect the cable.
Remove the charging board.
Make sure the interconnect cable is flipped up and the black antenna cable is routed through its groove on the right edge.
Set the charging board into its recess and press down on the edges to clip it into place.
Insert the point of a spudger under the left side of the vibration motor (near the small notch) and pry it up.
Remove the vibration motor.
