HMD Skyline Back Cover Replacement
  1. HMD Skyline Back Cover Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power off your phone.
  2. HMD Skyline Back Cover Replacement, Separate the back cover: step 2, image 1 of 3 HMD Skyline Back Cover Replacement, Separate the back cover: step 2, image 2 of 3 HMD Skyline Back Cover Replacement, Separate the back cover: step 2, image 3 of 3
    • A screw‑driven camshaft in the bottom left corner pushes the back cover away from the phone, creating a gap to begin separating the cover.
    • With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
  3. HMD Skyline Back Cover Replacement: step 3, image 1 of 3 HMD Skyline Back Cover Replacement: step 3, image 2 of 3 HMD Skyline Back Cover Replacement: step 3, image 3 of 3
    • Before separating the back cover, note the following:
    • There's a seam just under the back cover panel. Don't insert your tool here.
    • Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
    • Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
    • You should feel and hear the back cover clips release. If you don't, insert the pick deeper and try again.
  4. HMD Skyline Back Cover Replacement: step 4, image 1 of 3 HMD Skyline Back Cover Replacement: step 4, image 2 of 3 HMD Skyline Back Cover Replacement: step 4, image 3 of 3
    • Continue sliding the pick under the perimeter of the back cover to fully separate the clips and adhesive.
  5. HMD Skyline Back Cover Replacement, Remove the back cover: step 5, image 1 of 3 HMD Skyline Back Cover Replacement, Remove the back cover: step 5, image 2 of 3 HMD Skyline Back Cover Replacement, Remove the back cover: step 5, image 3 of 3
    • Lift and remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • If you're installing a new back cover:
    • Make sure you remove all liners from the underside.
    • Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
    • Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
2 other people completed this guide.
Spencer Day
156,272 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,842 Guides authored
1 Guide Comment
Hello, how can I order a back cover to Russia?
Gleb Andrusishin - Reply
Past 24 Hours: 0
Past 7 Days: 23
Past 30 Days: 87
All Time: 3,092
