HMDX Chill Charging Port Replacement
  1. HMDX Chill Charging Port Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Charging Port Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Charging Port Replacement, Remove Rubber Base: step 1, image 3 of 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Charging Port Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Charging Port Replacement: step 3, image 1 of 2 HMDX Chill Charging Port Replacement: step 3, image 2 of 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Charging Port Replacement, Motherboard: step 4, image 1 of 3 HMDX Chill Charging Port Replacement, Motherboard: step 4, image 2 of 3 HMDX Chill Charging Port Replacement, Motherboard: step 4, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Charging Port Replacement: step 5, image 1 of 1
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Charging Port Replacement: step 6, image 1 of 3 HMDX Chill Charging Port Replacement: step 6, image 2 of 3 HMDX Chill Charging Port Replacement: step 6, image 3 of 3
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Charging Port Replacement: step 7, image 1 of 2 HMDX Chill Charging Port Replacement: step 7, image 2 of 2
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Charging Port Replacement: step 8, image 1 of 1
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
  9. HMDX Chill Charging Port Replacement, Desolder the Charging Port: step 9, image 1 of 2 HMDX Chill Charging Port Replacement, Desolder the Charging Port: step 9, image 2 of 2
    • Using a soldering tool, desolder the charging port from the motherboard.
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
7 Guides authored
One Comment
I have the charging port removed. Where do I find a replacement??
Aaron Hughes - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 506
