HMDX Chill Front Buttons Replacement
  1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: step 1, image 3 of 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Front Buttons Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Front Buttons Replacement: step 3, image 1 of 2 HMDX Chill Front Buttons Replacement: step 3, image 2 of 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Front Buttons Replacement, Front Buttons: step 4, image 1 of 1
    • Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
    • These are located underneath the rubber base, prior to removal.
  5. HMDX Chill Front Buttons Replacement: step 5, image 1 of 2 HMDX Chill Front Buttons Replacement: step 5, image 2 of 2
    • Insert a spudger into the slit between the bottom of the buttons and the speaker base.
    • Push the buttons upwards, away from the base, until they come loose.
    • Use your hand to pull the linked buttons off the base.
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
7 Guides authored
One Comment
where can I buy new front buttons for replacement?
syanco_jim - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 470
