HMDX Chill Rubber Base Replacement
  1. HMDX Chill Rubber Base Replacement, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Rubber Base Replacement, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Rubber Base Replacement, Remove Rubber Base: step 1, image 3 of 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Rubber Base Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Rubber Base Replacement: step 3, image 1 of 2 HMDX Chill Rubber Base Replacement: step 3, image 2 of 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 9
All Time: 238
