HMDX Jam Plus Micro USB Jack Replacement
  1. HMDX Jam Plus  Micro USB Jack Replacement, Battery: step 1, image 1 of 3 HMDX Jam Plus  Micro USB Jack Replacement, Battery: step 1, image 2 of 3 HMDX Jam Plus  Micro USB Jack Replacement, Battery: step 1, image 3 of 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus  Micro USB Jack Replacement: step 2, image 1 of 2 HMDX Jam Plus  Micro USB Jack Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus  Micro USB Jack Replacement: step 3, image 1 of 2 HMDX Jam Plus  Micro USB Jack Replacement: step 3, image 2 of 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus  Micro USB Jack Replacement: step 4, image 1 of 3 HMDX Jam Plus  Micro USB Jack Replacement: step 4, image 2 of 3 HMDX Jam Plus  Micro USB Jack Replacement: step 4, image 3 of 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus  Micro USB Jack Replacement: step 5, image 1 of 3 HMDX Jam Plus  Micro USB Jack Replacement: step 5, image 2 of 3 HMDX Jam Plus  Micro USB Jack Replacement: step 5, image 3 of 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus  Micro USB Jack Replacement: step 6, image 1 of 2 HMDX Jam Plus  Micro USB Jack Replacement: step 6, image 2 of 2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: step 7, image 1 of 2 HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: step 7, image 2 of 2
    • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
  8. HMDX Jam Plus  Micro USB Jack Replacement: step 8, image 1 of 2 HMDX Jam Plus  Micro USB Jack Replacement: step 8, image 2 of 2
    • Carefully lift the main board away from the plastic.
    • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
  9. HMDX Jam Plus  Micro USB Jack Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
    • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
    • Do not apply too much heat to the board as it may damage other portions of the board.
Maxwell Erickson
587 Reputation
4 Guides authored
Montana Tech, Team 10-3, Shirk Fall 2015 Member of Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 933
