HP 15-AF131DX Fan Replacement
  1. HP 15-AF131DX Fan Replacement, Fan: step 1, image 1 of 2 HP 15-AF131DX Fan Replacement, Fan: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Fan Replacement: step 2, image 1 of 2 HP 15-AF131DX Fan Replacement: step 2, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Turn the computer over and use a card to pry the space between the keyboard and bottom surface of the computer.
    • 'Work a plastic card or opening tool carefully around the three edges'' (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the fan.
  3. HP 15-AF131DX Fan Replacement: step 3, image 1 of 2 HP 15-AF131DX Fan Replacement: step 3, image 2 of 2
    • To replace the fan remove the two screws that hold the fan in place.
    • Unplug the wire that connects the fan.
    • Remove the fan.
3 other people completed this guide.
Anthony Martinez
556 Reputation
3 Guides authored
Cal Poly, Team S6-G2, Banghart Fall 2017 Member of Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,694
