HP 15-BA078DX Touchscreen Replacement
  1. HP 15-BA078DX Touchscreen Replacement, Battery: step 1, image 1 of 3 HP 15-BA078DX Touchscreen Replacement, Battery: step 1, image 2 of 3 HP 15-BA078DX Touchscreen Replacement, Battery: step 1, image 3 of 3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX Touchscreen Replacement, Touchscreen: step 2, image 1 of 3 HP 15-BA078DX Touchscreen Replacement, Touchscreen: step 2, image 2 of 3 HP 15-BA078DX Touchscreen Replacement, Touchscreen: step 2, image 3 of 3
    • Carefully use the blue plastic opening tool to remove the outer frame of the screen.
  3. HP 15-BA078DX Touchscreen Replacement: step 3, image 1 of 3 HP 15-BA078DX Touchscreen Replacement: step 3, image 2 of 3 HP 15-BA078DX Touchscreen Replacement: step 3, image 3 of 3
    • Flip the laptop on its back.
    • Detach the bottom section of the screen frame from the laptop by using the black nylon spudger.
  4. HP 15-BA078DX Touchscreen Replacement: step 4, image 1 of 1
    • Separate the frame from the screen.
  5. HP 15-BA078DX Touchscreen Replacement: step 5, image 1 of 3 HP 15-BA078DX Touchscreen Replacement: step 5, image 2 of 3 HP 15-BA078DX Touchscreen Replacement: step 5, image 3 of 3
    • Using the Phillips #0 screwdriver, unscrew the 4 screws around the frame.
  6. HP 15-BA078DX Touchscreen Replacement: step 6, image 1 of 3 HP 15-BA078DX Touchscreen Replacement: step 6, image 2 of 3 HP 15-BA078DX Touchscreen Replacement: step 6, image 3 of 3
    • Remove the touchscreen from the laptop.
    • Be careful not to damage the screen connector located at the bottom of the screen.
2 other people completed this guide.
Matthew Moore
341 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 477
