HP 15-R011DX Cooling Fan Replacement
  1. HP 15-R011DX Cooling Fan Replacement, Battery: step 1, image 1 of 2 HP 15-R011DX Cooling Fan Replacement, Battery: step 1, image 2 of 2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX Cooling Fan Replacement: step 2, image 1 of 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX Cooling Fan Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 1 of 2 HP 15-R011DX Cooling Fan Replacement, How to Access the Internal Components of an HP 15-R011DX: step 3, image 2 of 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX Cooling Fan Replacement: step 4, image 1 of 2 HP 15-R011DX Cooling Fan Replacement: step 4, image 2 of 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX Cooling Fan Replacement: step 5, image 1 of 2 HP 15-R011DX Cooling Fan Replacement: step 5, image 2 of 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX Cooling Fan Replacement: step 6, image 1 of 3 HP 15-R011DX Cooling Fan Replacement: step 6, image 2 of 3 HP 15-R011DX Cooling Fan Replacement: step 6, image 3 of 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX Cooling Fan Replacement: step 7, image 1 of 2 HP 15-R011DX Cooling Fan Replacement: step 7, image 2 of 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX Cooling Fan Replacement, Hard Drive: step 8, image 1 of 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX Cooling Fan Replacement: step 9, image 1 of 2 HP 15-R011DX Cooling Fan Replacement: step 9, image 2 of 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX Cooling Fan Replacement: step 10, image 1 of 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
  11. HP 15-R011DX Cooling Fan Replacement, Motherboard: step 11, image 1 of 2 HP 15-R011DX Cooling Fan Replacement, Motherboard: step 11, image 2 of 2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
  12. HP 15-R011DX Cooling Fan Replacement: step 12, image 1 of 1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
  13. HP 15-R011DX Cooling Fan Replacement: step 13, image 1 of 1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
  14. HP 15-R011DX Cooling Fan Replacement: step 14, image 1 of 1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
  15. HP 15-R011DX Cooling Fan Replacement: step 15, image 1 of 1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
  16. HP 15-R011DX Cooling Fan Replacement, Cooling Fan: step 16, image 1 of 1
    • The cooling fan assembly is located on the underside of the motherboard.
    • Using a Phillips #1 screwdriver, remove the three 5mm screws that secure the cooling fan assembly to the motherboard.
  17. HP 15-R011DX Cooling Fan Replacement: step 17, image 1 of 1
    • Separate the cooling fan assembly from the motherboard and proceed to use the canned air to clean the inner pieces of the fan.
    • You can now clean the inner parts of the fan assembly or replace with a new assembly.
  18. HP 15-R011DX Cooling Fan Replacement: step 18, image 1 of 1
    • Before reconnecting the cooling fan assembly, make sure to properly apply thermal paste and touch the two connectors together when reassembling your laptop.
Joshua Brockman
368 Reputation
2 Guides authored
1 Guide Comment
It appears as though the jfan1 connection on the motherboard doesn’t have a plastic connector. I’ve bought a fan for this laptop to solve some overheating issues, but I can’t find anywhere to plug it in (I’m assuming that on similar models, the jfan1 connection would be the one to use). Is there any way that I can somehow plug my fan into this motherboard?
Brandon Peterson - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,413
