HP 15-R263DX Hard Drive Replacement
  1. HP 15-R263DX Hard Drive Replacement, Battery: step 1, image 1 of 2 HP 15-R263DX Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
  2. HP 15-R263DX Hard Drive Replacement, Optical Drive: step 2, image 1 of 2 HP 15-R263DX Hard Drive Replacement, Optical Drive: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
  3. HP 15-R263DX Hard Drive Replacement: step 3, image 1 of 1
    • Gently slide the optical drive out of the side of the computer.
  4. HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: step 4, image 1 of 2 HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: step 4, image 2 of 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
  5. HP 15-R263DX Hard Drive Replacement: step 5, image 1 of 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
  6. HP 15-R263DX Hard Drive Replacement: step 6, image 1 of 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
  7. HP 15-R263DX Hard Drive Replacement: step 7, image 1 of 2 HP 15-R263DX Hard Drive Replacement: step 7, image 2 of 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
  8. HP 15-R263DX Hard Drive Replacement: step 8, image 1 of 2 HP 15-R263DX Hard Drive Replacement: step 8, image 2 of 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
  9. HP 15-R263DX Hard Drive Replacement: step 9, image 1 of 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
  10. HP 15-R263DX Hard Drive Replacement, Hard Drive: step 10, image 1 of 1
    • Remove the 2 black screws holding the hard drive to the computer frame.
  11. HP 15-R263DX Hard Drive Replacement: step 11, image 1 of 2 HP 15-R263DX Hard Drive Replacement: step 11, image 2 of 2
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
2 other people completed this guide.
Drake Hort
487 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 37
All Time: 1,766
