HP 15-ac142dx CMOS Battery Replacement
Nicole Mathieu
Nicole Mathieu and 4 other contributors
Last updated on January 20, 2025
2 minutes
Easy
Needs More Images
Missing Steps
Introduction
Go to step 1
Follow this guide to replace the CMOS battery in your HP 15-ac142dx laptop.
The CMOS battery (sometimes referred to as the RTC/"Real Time Clock" battery) helps maintain system settings such as the date, time, and BIOS settings when your laptop is turned off. If these settings aren't being maintained between power cycles, you may need to replace the CMOS battery.
Tools
Show more…
  1. HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 1, image 1 of 3 HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 1, image 2 of 3 HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 1, image 3 of 3
    • Turn off your laptop and flip it upside down onto a flat surface.
    • Slide the battery lock tabs towards each other to unlock the battery.
    • Lift the battery from the center and remove.
  2. HP 15-ac142dx CMOS Battery Replacement, Reassembly information: step 2, image 1 of 1
    • To replace the battery:
    • Align the new battery with the cut-out in the laptop.
    • Insert the battery into it slot until you hear a "click" indicating the battery is fully seated.
  3. HP 15-ac142dx CMOS Battery Replacement, Disassemble the laptop: step 3, image 1 of 1
    • Turn off your laptop and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  4. HP 15-ac142dx CMOS Battery Replacement: step 4, image 1 of 2 HP 15-ac142dx CMOS Battery Replacement: step 4, image 2 of 2
    • Flip your laptop back over and use an opening tool to pry the keyboard up from the bottom case.
    • Locate the motherboard battery.
  5. HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 5, image 1 of 2 HP 15-ac142dx CMOS Battery Replacement, Remove the battery: step 5, image 2 of 2
    • These photos are of a different device, but the procedure is identical.
    • Use the tip of a spudger to pry the motherboard battery out of its socket.
    • To install a new battery, insert it into its slot and press down firmly.
Nicole Mathieu
647 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 822
