HP 15-af123cl RAM Replacement
  1. HP 15-af123cl RAM Replacement, Battery: step 1, image 1 of 2 HP 15-af123cl RAM Replacement, Battery: step 1, image 2 of 2
    • Push the slider with a lock symbol to the right to unlock the battery.
  2. HP 15-af123cl RAM Replacement: step 2, image 1 of 1
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
  3. HP 15-af123cl RAM Replacement, Back Cover: step 3, image 1 of 1
    • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
  4. HP 15-af123cl RAM Replacement: step 4, image 1 of 3 HP 15-af123cl RAM Replacement: step 4, image 2 of 3 HP 15-af123cl RAM Replacement: step 4, image 3 of 3
    • Turn the laptop over and open the lid.
    • Use an opening tool to pry the bottom cover from the body of the laptop.
  5. HP 15-af123cl RAM Replacement: step 5, image 1 of 2 HP 15-af123cl RAM Replacement: step 5, image 2 of 2
    • Close and turn over the laptop again.
    • Pull the back cover up to remove it from the laptop.
  6. HP 15-af123cl RAM Replacement, RAM: step 6, image 1 of 1
    • Press the metal brackets on either side of the RAM outwards.
  7. HP 15-af123cl RAM Replacement: step 7, image 1 of 1
    • Remove the RAM from the laptop.
Victoria Santos
704 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 543
