HP 15-ay091ms Fan Replacement
  1. HP 15-ay091ms Fan Replacement, Battery: step 1, image 1 of 2 HP 15-ay091ms Fan Replacement, Battery: step 1, image 2 of 2
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms Fan Replacement, Back Panel: step 2, image 1 of 3 HP 15-ay091ms Fan Replacement, Back Panel: step 2, image 2 of 3 HP 15-ay091ms Fan Replacement, Back Panel: step 2, image 3 of 3
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms Fan Replacement, Fan: step 3, image 1 of 3 HP 15-ay091ms Fan Replacement, Fan: step 3, image 2 of 3 HP 15-ay091ms Fan Replacement, Fan: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the screws holding the fan in place using a JIS #0 screwdriver.
    • Use a pair of tweezers to disconnect the wiring that powers the fan.
    • Remove the fan.
Gabriel
145 Reputation
2 Guides authored
Gateway, Team A-1, Gonzalez Fall 2023 Member of Gateway, Team A-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23SAG1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 46
