HP 15-bs168cl Screen Replacement
  1. HP 15-bs168cl Screen Replacement, Screen: step 1, image 1 of 2 HP 15-bs168cl Screen Replacement, Screen: step 1, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Open the device so the screen is facing out.
    • Slide a thin plastic card into the space between the screen and the bezel. Slide the card around the entire screen to detach the case.
    • There is glue at the bottom so extra force may be needed to remove it.
  2. HP 15-bs168cl Screen Replacement: step 2, image 1 of 3 HP 15-bs168cl Screen Replacement: step 2, image 2 of 3 HP 15-bs168cl Screen Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to unscrew the four screws at the top corners and the two screws at the bottom corners.
  3. HP 15-bs168cl Screen Replacement: step 3, image 1 of 1
    • Remove the screen from the frame.
    • Remove the tape on the cable connected to the screen. Unplug the cable.
2 other people completed this guide.
Ian Gascon
792 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 881
