HP 15-d076nr RAM Replacement
  1. HP 15-d076nr RAM Replacement, RAM: step 1, image 1 of 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces away from you.
  2. HP 15-d076nr RAM Replacement: step 2, image 1 of 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  3. HP 15-d076nr RAM Replacement: step 3, image 1 of 2 HP 15-d076nr RAM Replacement: step 3, image 2 of 2
    • Carefully pry the middle panel up using a plastic spudger or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  4. HP 15-d076nr RAM Replacement: step 4, image 1 of 1
    • Locate the RAM in the exposed area.
  5. HP 15-d076nr RAM Replacement: step 5, image 1 of 3 HP 15-d076nr RAM Replacement: step 5, image 2 of 3 HP 15-d076nr RAM Replacement: step 5, image 3 of 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
  6. HP 15-d076nr RAM Replacement: step 6, image 1 of 1
    • Remove the RAM.
Amy Weed
577 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 667
