HP 15-da0002dx Battery Replacement
  1. HP 15-da0002dx Battery Replacement, Back Cover: step 1, image 1 of 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Battery Replacement: step 2, image 1 of 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Battery Replacement: step 3, image 1 of 2 HP 15-da0002dx Battery Replacement: step 3, image 2 of 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Battery Replacement: step 4, image 1 of 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Battery Replacement: step 5, image 1 of 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Battery Replacement: step 6, image 1 of 2 HP 15-da0002dx Battery Replacement: step 6, image 2 of 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Battery Replacement: step 7, image 1 of 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Battery Replacement, Battery: step 8, image 1 of 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Battery Replacement: step 9, image 1 of 2 HP 15-da0002dx Battery Replacement: step 9, image 2 of 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
3 other people completed this guide.
One Comment
Where to find, buy the same battery spare???
Divya Lekha - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 4,144
