HP 15-da0012dx SSD Replacement
Xavier Hung
Xavier Hung and 5 other contributors
Last updated on August 1, 2023
20 minutes
Moderate
Featured Student Guide
Introduction
Go to step 1
If the laptop does not boot correctly after running the "Startup Repair" from the Windows 10 DVD, use this guide to remove and replace your SSD. You will need a plastic opening tool and a Phillips #1 screwdriver head.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. HP 15-da0012dx SSD Replacement, Battery: step 1, image 1 of 2 HP 15-da0012dx SSD Replacement, Battery: step 1, image 2 of 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: step 2, image 1 of 3 HP 15-da0012dx SSD Replacement: step 2, image 2 of 3 HP 15-da0012dx SSD Replacement: step 2, image 3 of 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: step 3, image 1 of 2 HP 15-da0012dx SSD Replacement: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: step 4, image 1 of 2 HP 15-da0012dx SSD Replacement: step 4, image 2 of 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: step 5, image 1 of 3 HP 15-da0012dx SSD Replacement: step 5, image 2 of 3 HP 15-da0012dx SSD Replacement: step 5, image 3 of 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: step 6, image 1 of 2 HP 15-da0012dx SSD Replacement: step 6, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: step 7, image 1 of 2 HP 15-da0012dx SSD Replacement: step 7, image 2 of 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: step 8, image 1 of 2 HP 15-da0012dx SSD Replacement, SSD: step 8, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: step 9, image 1 of 2 HP 15-da0012dx SSD Replacement: step 9, image 2 of 2
    • Pull the SSD module away from the socket.
6 other people completed this guide.
Xavier Hung
959 Reputation
4 Guides authored
UC Davis, Team S20-G4, Lore Winter 2019 Member of UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
3 Members
7 Guides authored
One Comment
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - Reply
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 81
All Time: 9,482
