HP 15-da0012dx Trackpad and Keyboard Replacement
  1. HP 15-da0012dx Trackpad and Keyboard Replacement, Battery: step 1, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement, Battery: step 1, image 2 of 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Trackpad and Keyboard Replacement: step 2, image 1 of 3 HP 15-da0012dx Trackpad and Keyboard Replacement: step 2, image 2 of 3 HP 15-da0012dx Trackpad and Keyboard Replacement: step 2, image 3 of 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Trackpad and Keyboard Replacement: step 3, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Trackpad and Keyboard Replacement: step 4, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 4, image 2 of 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Trackpad and Keyboard Replacement: step 5, image 1 of 3 HP 15-da0012dx Trackpad and Keyboard Replacement: step 5, image 2 of 3 HP 15-da0012dx Trackpad and Keyboard Replacement: step 5, image 3 of 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Trackpad and Keyboard Replacement: step 6, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 6, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Trackpad and Keyboard Replacement: step 7, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 7, image 2 of 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx Trackpad and Keyboard Replacement, RAM: step 8, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement, RAM: step 8, image 2 of 2
    • Spread the retention clips on either side of the RAM module outward until you hear a click sound.
    • The RAM module should tilt up at a 45 degree angle.
  9. HP 15-da0012dx Trackpad and Keyboard Replacement: step 9, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 9, image 2 of 2
    • Grasp the edge of the RAM module and pull it away from the slot.
    • Follow Steps 8 and 9 to remove both RAM modules.
  10. HP 15-da0012dx Trackpad and Keyboard Replacement, SSD: step 10, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement, SSD: step 10, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  11. HP 15-da0012dx Trackpad and Keyboard Replacement: step 11, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 11, image 2 of 2
    • Pull the SSD module away from the socket.
  12. HP 15-da0012dx Trackpad and Keyboard Replacement, Motherboard: step 12, image 1 of 1
    • Using the Phillips #1 Screwdriver, remove the single 3.0 mm screw holding the wifi card and gently pull the wifi card away.
  13. HP 15-da0012dx Trackpad and Keyboard Replacement: step 13, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 13, image 2 of 2
    • Using the Phillips #1 Screwdriver, remove the four 3.0 mm screws holding the heat sink in place.
    • Gently pull the heat sink out of the laptop.
  14. HP 15-da0012dx Trackpad and Keyboard Replacement: step 14, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 14, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the small circuit board.
    • Gently remove the small circuit board.
  15. HP 15-da0012dx Trackpad and Keyboard Replacement: step 15, image 1 of 3 HP 15-da0012dx Trackpad and Keyboard Replacement: step 15, image 2 of 3 HP 15-da0012dx Trackpad and Keyboard Replacement: step 15, image 3 of 3
    Tool used on this step:
    Buy
    • Using the metal tweezers, disconnect the ribbon cables from the motherboard .
    • First remove the USB board cable followed by the keyboard and touchpad cables.
  16. HP 15-da0012dx Trackpad and Keyboard Replacement: step 16, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the USB card in place.
    • Gently remove the USB card from the laptop.
  17. HP 15-da0012dx Trackpad and Keyboard Replacement: step 17, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 17, image 2 of 2
    • Remove the speaker cable from the cable holder.
    • Tilt the bottom of the laptop up 30 degrees to move the monitor holders up to allow access to the rest of the laptop, and then return the laptop to its original state.
  18. HP 15-da0012dx Trackpad and Keyboard Replacement: step 18, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 18, image 2 of 2
    • Using the Phillips #1 Screwdriver, remove the 3 mm screw from the motherboard.
    • Carefully remove the motherboard.
  19. HP 15-da0012dx Trackpad and Keyboard Replacement, Trackpad and Keyboard: step 19, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the 3mm screws holding the speakers in place.
    • Carefully lift the speakers out of the laptop.
  20. HP 15-da0012dx Trackpad and Keyboard Replacement: step 20, image 1 of 1
    Buy
    • Use tweezers to remove the power connector from the laptop.
    • Carefully remove the power jack.
  21. HP 15-da0012dx Trackpad and Keyboard Replacement: step 21, image 1 of 2 HP 15-da0012dx Trackpad and Keyboard Replacement: step 21, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the two 3 mm screws holding the mouse buttons board down.
    • Carefully remove the mouse buttons board.
    • What remains is the keyboard, trackpad, and top case assembly.
4 other people completed this guide.
One Comment
You omitted the step to remove the screen assem and also the fan
John Syngajewski - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 2,037
