HP 15-db0015dx Battery Replacement
  1. HP 15-db0015dx Battery Replacement, Battery: step 1, image 1 of 2 HP 15-db0015dx Battery Replacement, Battery: step 1, image 2 of 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx Battery Replacement: step 2, image 1 of 3 HP 15-db0015dx Battery Replacement: step 2, image 2 of 3 HP 15-db0015dx Battery Replacement: step 2, image 3 of 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx Battery Replacement: step 3, image 1 of 3 HP 15-db0015dx Battery Replacement: step 3, image 2 of 3 HP 15-db0015dx Battery Replacement: step 3, image 3 of 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
8 other people completed this guide.
One Comment
Dobrej schanim zakladovou desku na HP Pavilion 15-db005dx Palmrest ,
Mohli bysta mi poradit kde ji koupim predem dekuji za odpoved.
jiri Zavurka - Reply
Past 24 Hours: 10
Past 7 Days: 27
Past 30 Days: 110
All Time: 6,280
