HP 15-db0015dx Optical Drive Replacement
  1. HP 15-db0015dx Optical Drive Replacement, Optical Drive: step 1, image 1 of 3 HP 15-db0015dx Optical Drive Replacement, Optical Drive: step 1, image 2 of 3 HP 15-db0015dx Optical Drive Replacement, Optical Drive: step 1, image 3 of 3
    • Make sure the disc drive is clear of any discs.
    • Remove the rubber stays from the bottom of the device.
    • Using a Phillips #0 screwdriver, remove the eleven screws on the back cover.
  2. HP 15-db0015dx Optical Drive Replacement: step 2, image 1 of 3 HP 15-db0015dx Optical Drive Replacement: step 2, image 2 of 3 HP 15-db0015dx Optical Drive Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back cover.
    • The disk drive must be disconnected by pulling it to the left before removing the back panel.
  3. HP 15-db0015dx Optical Drive Replacement: step 3, image 1 of 3 HP 15-db0015dx Optical Drive Replacement: step 3, image 2 of 3 HP 15-db0015dx Optical Drive Replacement: step 3, image 3 of 3
    • Slide the disk drive to the left and remove.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 968
