HP 15-dy2702dx Battery Replacement
  1. HP 15-dy2702dx Battery Replacement, Lower Case: step 1, image 1 of 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Battery Replacement: step 2, image 1 of 1
    • Unscrew all 8 Phillips #1 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Battery Replacement: step 3, image 1 of 2 HP 15-dy2702dx Battery Replacement: step 3, image 2 of 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Battery Replacement: step 4, image 1 of 2 HP 15-dy2702dx Battery Replacement: step 4, image 2 of 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Battery Replacement: step 5, image 1 of 3 HP 15-dy2702dx Battery Replacement: step 5, image 2 of 3 HP 15-dy2702dx Battery Replacement: step 5, image 3 of 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Battery Replacement, Battery: step 6, image 1 of 2 HP 15-dy2702dx Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #1 screwdriver.
  7. HP 15-dy2702dx Battery Replacement: step 7, image 1 of 3 HP 15-dy2702dx Battery Replacement: step 7, image 2 of 3 HP 15-dy2702dx Battery Replacement: step 7, image 3 of 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
September Oo
397 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2023 Member of Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 82
All Time: 909
