HP 15-ef2025nr Battery Replacement
  1. HP 15-ef2025nr Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Battery Replacement: step 2, image 1 of 2 HP 15-ef2025nr Battery Replacement: step 2, image 2 of 2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Battery Replacement: step 3, image 1 of 2 HP 15-ef2025nr Battery Replacement: step 3, image 2 of 2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Battery Replacement: step 4, image 1 of 2 HP 15-ef2025nr Battery Replacement: step 4, image 2 of 2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Battery Replacement: step 5, image 1 of 3 HP 15-ef2025nr Battery Replacement: step 5, image 2 of 3 HP 15-ef2025nr Battery Replacement: step 5, image 3 of 3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 355
