HP 15-f009wm RAM Replacement
  1. HP 15-f009wm RAM Replacement, Battery: step 1, image 1 of 2 HP 15-f009wm RAM Replacement, Battery: step 1, image 2 of 2
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm RAM Replacement: step 2, image 1 of 3 HP 15-f009wm RAM Replacement: step 2, image 2 of 3 HP 15-f009wm RAM Replacement: step 2, image 3 of 3
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm RAM Replacement: step 3, image 1 of 2 HP 15-f009wm RAM Replacement: step 3, image 2 of 2
    • Slide the battery out.
  4. HP 15-f009wm RAM Replacement, RAM: step 4, image 1 of 3 HP 15-f009wm RAM Replacement, RAM: step 4, image 2 of 3 HP 15-f009wm RAM Replacement, RAM: step 4, image 3 of 3
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm RAM Replacement: step 5, image 1 of 3 HP 15-f009wm RAM Replacement: step 5, image 2 of 3 HP 15-f009wm RAM Replacement: step 5, image 3 of 3
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm RAM Replacement: step 6, image 1 of 3 HP 15-f009wm RAM Replacement: step 6, image 2 of 3 HP 15-f009wm RAM Replacement: step 6, image 3 of 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm RAM Replacement: step 7, image 1 of 1
    • Remove the RAM chip from the laptop.
Alex Birchler
1,008 Reputation
5 Guides authored
USF Tampa, Team S2-G2, Nance Spring 2018 Member of USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 628
