HP 15-f162dx RAM Replacement
  1. HP 15-f162dx RAM Replacement, RAM: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin the repair.
  2. HP 15-f162dx RAM Replacement: step 2, image 1 of 1
    • Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
    • Remove it at an angle and not straight up so you don't damage the socket.
  3. HP 15-f162dx RAM Replacement: step 3, image 1 of 1
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • The RAM will pop up by a few millimeters.
    • Repeat steps in reverse order to reassemble the computer with new RAM
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 416
