Introduction
Does your hard-drive not have enough storage and you want to swap it for a larger storage hard-drive? Well, reading this guide will show how. To disassembly the hard-drive on this computer, it is very easy and will only take about 5 minutes. This guide helps you to replace the hard drive, which can also solve the problem that the computer is making too much noise.
*The hard drive for this device is missing. We have substituted the drive with paper for demonstration. It should not be a problem for the reader to understand the steps, however, the specific measurements of hard drive screws have not been provided in this guide.
Flip the laptop over so that the bottom is facing you.
Slide the latch towards the center of the laptop so the unlock emblem appears.
Remove the two screws securing the hard drive to the device using the Phillips #0 screwdriver.
3 other people completed this guide.
One Comment
Be really careful when removing the top case, around the keyboard because there are a couple of really cheap ribbon cables. One connects the power button, another the trackpad. I have to buy a replacement cable and power button board now because I pulled the top case off too quickly and broke the connection at the power button board.
The plastic top case around the keyboard snaps onto the lower part of the case, with many, many tabs and doesn’t even need screws to stay together. You’ll have to wrestle with it, but don’t pull it too far from the lower case.
