HP 15-r137wm TouchSmart Cooling Fan Replacement
  1. HP 15-r137wm TouchSmart Cooling Fan Replacement, Front Panel Assembly: step 1, image 1 of 3 HP 15-r137wm TouchSmart Cooling Fan Replacement, Front Panel Assembly: step 1, image 2 of 3 HP 15-r137wm TouchSmart Cooling Fan Replacement, Front Panel Assembly: step 1, image 3 of 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Cooling Fan Replacement: step 2, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Cooling Fan Replacement: step 3, image 1 of 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Cooling Fan Replacement: step 4, image 1 of 2 HP 15-r137wm TouchSmart Cooling Fan Replacement: step 4, image 2 of 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Cooling Fan Replacement, Keyboard: step 5, image 1 of 2 HP 15-r137wm TouchSmart Cooling Fan Replacement, Keyboard: step 5, image 2 of 2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Cooling Fan Replacement: step 6, image 1 of 2 HP 15-r137wm TouchSmart Cooling Fan Replacement: step 6, image 2 of 2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Cooling Fan Replacement, Cooling Fan: step 7, image 1 of 2 HP 15-r137wm TouchSmart Cooling Fan Replacement, Cooling Fan: step 7, image 2 of 2
    • Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
    • Slowly disconnect the cable as the wires are very small and fragile
  8. HP 15-r137wm TouchSmart Cooling Fan Replacement: step 8, image 1 of 2 HP 15-r137wm TouchSmart Cooling Fan Replacement: step 8, image 2 of 2
    • Remove the three (3) 2.5mm by 3.5mm Phillips #0 screws from the fan.
  9. HP 15-r137wm TouchSmart Cooling Fan Replacement: step 9, image 1 of 1
    • Remove the cooling fan from the housing carefully.
    • The fan may be connected to the small foam screen. Pull gently to release it.
Ross B Jacques
881 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 393
