HP 17-bs049dx Fan Replacement
  1. HP 17-bs049dx Fan Replacement, Battery: step 1, image 1 of 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Fan Replacement, Back Panel: step 2, image 1 of 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Fan Replacement: step 3, image 1 of 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Fan Replacement: step 4, image 1 of 2 HP 17-bs049dx Fan Replacement: step 4, image 2 of 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Fan Replacement: step 5, image 1 of 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx Fan Replacement, Fan: step 6, image 1 of 3 HP 17-bs049dx Fan Replacement, Fan: step 6, image 2 of 3 HP 17-bs049dx Fan Replacement, Fan: step 6, image 3 of 3
    • Unscrew all four screws connecting the heatsink to the motherboard.
    • The screws holding the heat sink will not detach from the heat sink.
    • All four screws must be loosened before removing the heat sink.
    • After loosening all screws remove the heat sink and store it in a safe place.
  7. HP 17-bs049dx Fan Replacement: step 7, image 1 of 1
    • After removing the heat sink, disconnect the cable connecting the fan to the motherboard.
  8. HP 17-bs049dx Fan Replacement: step 8, image 1 of 1
    • Remove the old fan from the device.
Juan Seoane-Seri
183 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 922
