HP 17-x027ds LCD Screen Replacement
  1. HP 17-x027ds LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 HP 17-x027ds LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 HP 17-x027ds LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Open the laptop so you can see the screen.
    • Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
    • Remove the bezel by starting on the sides of the screen and lastly removing the top outlining.
    • When removing the bezel, be cautious not to use too much force or else you will damage the screen. Apply just enough pressure to create a gap between the bezel and screen.
  2. HP 17-x027ds LCD Screen Replacement: step 2, image 1 of 3 HP 17-x027ds LCD Screen Replacement: step 2, image 2 of 3 HP 17-x027ds LCD Screen Replacement: step 2, image 3 of 3
    • Lift the bezel off the screen to see the outlines of the LCD screen.
    • Remove the four black 3mm screws in each corner of the screen with a JIS #1 screwdriver.
    • Remove the two silver 4mm screws located at the top of the screen with a JIS #1 screwdriver.
  3. HP 17-x027ds LCD Screen Replacement: step 3, image 1 of 2 HP 17-x027ds LCD Screen Replacement: step 3, image 2 of 2
    • Remove the LCD screen and place it on the keyboard.
    • Disconnect the video cable to completely detach the LCD screen.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 671
