HP 17-x027ds Wifi Card Replacement
  1. HP 17-x027ds Wifi Card Replacement, WiFi Card: step 1, image 1 of 3 HP 17-x027ds Wifi Card Replacement, WiFi Card: step 1, image 2 of 3 HP 17-x027ds Wifi Card Replacement, WiFi Card: step 1, image 3 of 3
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top.
    • Remove the battery by pulling it out.
  2. HP 17-x027ds Wifi Card Replacement: step 2, image 1 of 3 HP 17-x027ds Wifi Card Replacement: step 2, image 2 of 3 HP 17-x027ds Wifi Card Replacement: step 2, image 3 of 3
    • Remove the 2 pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the 2 black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm screws with a JIS #00 screwdriver.
  3. HP 17-x027ds Wifi Card Replacement: step 3, image 1 of 2 HP 17-x027ds Wifi Card Replacement: step 3, image 2 of 2
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  4. HP 17-x027ds Wifi Card Replacement: step 4, image 1 of 3 HP 17-x027ds Wifi Card Replacement: step 4, image 2 of 3 HP 17-x027ds Wifi Card Replacement: step 4, image 3 of 3
    • Carefully pull the two cables attached to the CPU.
    • They are labeled 1 and 2. When putting the cables back, make sure to put them in the correct section.
    • Remove the screw holding down the CPU with the same screwdriver tip as before.
    • Gently pull on the CPU to remove it.
Tyrin
188 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 361
