HP 310-1037 Hard Drive Replacement
  1. HP 310-1037 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 HP 310-1037 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 HP 310-1037 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
    • Lay the PC flat on the front to gain access to the stand cover
    • Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
  2. HP 310-1037 Hard Drive Replacement: step 2, image 1 of 3 HP 310-1037 Hard Drive Replacement: step 2, image 2 of 3 HP 310-1037 Hard Drive Replacement: step 2, image 3 of 3
    • Remove the stand cover
    • The hard drive caddy is held in place with 1 Phillips screw
    • Use a #0 Phillips screwdriver to remove that screw
  3. HP 310-1037 Hard Drive Replacement: step 3, image 1 of 3 HP 310-1037 Hard Drive Replacement: step 3, image 2 of 3 HP 310-1037 Hard Drive Replacement: step 3, image 3 of 3
    • Lift the handle on the hard drive caddy
    • and pull it to the backside. This will remove the hard drive caddy from the computer.
    • To remove the hard drive from the caddy, turn it over. There are four Phillips scres that hold the hard drive in place.
  4. HP 310-1037 Hard Drive Replacement: step 4, image 1 of 2 HP 310-1037 Hard Drive Replacement: step 4, image 2 of 2
    • Once the four screws are removed, slide the hard drive out of the caddy.
    • Here is the failed drive. It is a Hitachi HDS721010CLA332. Failure with this drive is all to common.
6 other people completed this guide.
oldturkey03
789,521 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
One Comment
This one made me laugh - Remove two screws. Pull the drive out. Difficulty: Moderate.
LOL
Justin Coope - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 4,808
