HP 5406 zl Switch Chassis (J8697A) Replacement
  1. HP 5406 zl Switch Chassis (J8697A) Replacement, Identifying the modules: step 1, image 1 of 2 HP 5406 zl Switch Chassis (J8697A) Replacement, Identifying the modules: step 1, image 2 of 2
    • The equipment comes with two modules to install a supervisor card and 6 expansion slots for compatible modules.
    • J8726A Management Module.'
    • J8705A Module 20p 10/100/1000 + 4p SFP.
    • 'RESET' and 'CLEAR' buttons used for: 'CLEAR' Erase only the access passwords when pressed for at least 1 second. 'RESET' Restores factory default settings when pressed in a specific pattern.
    • RS232 console port; any baud rate from 2400 to 115200 (the switch automatically detects the speed) 8 data bits, 1 stop bit, no parity and flow control set to None
    • USB port
    • J4858C - HP Gigabit-SX-LC Mini-GBIC
  2. HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the expansion modules: step 2, image 1 of 3 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the expansion modules: step 2, image 2 of 3 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the expansion modules: step 2, image 3 of 3
    • The modules can be removed with the equipment turned on, with the exception of the 'Management Module'.
    • Loosen the screws, the screw contains a spring and once it is loose it will be ejected and will remain in the equipment.
    • To remove the module, pull the handles that are on the bottom of the module.
  3. HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the Managment Module: step 3, image 1 of 3 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the Managment Module: step 3, image 2 of 3 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the Managment Module: step 3, image 3 of 3
    • Do not remove while the equipment is on
    • Following the same procedure above, loosen the screws and pull the levers of the module to remove it.
    • RAM Memory
    • Flash card
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Eneider Colina
2,370 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 54
All Time: 2,220
