HP 7 Plus 1302 Back Cover Replacement
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: step 2, image 1 of 2 HP 7 Plus 1302 Back Cover Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: step 3, image 1 of 2 HP 7 Plus 1302 Back Cover Replacement: step 3, image 2 of 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
Marquies
245 Reputation
1 Guide authored
IUPUI, Team 1-2, Renguette SU 2015 Member of IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,215
