HP 7 Plus 1302 Headphone Jack Replacement
  1. HP 7 Plus 1302 Headphone Jack Replacement, Back Cover: step 1, image 1 of 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Headphone Jack Replacement: step 2, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Headphone Jack Replacement: step 3, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 3, image 2 of 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Headphone Jack Replacement, Battery: step 4, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement, Battery: step 4, image 2 of 2
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Headphone Jack Replacement: step 5, image 1 of 1
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Headphone Jack Replacement, Motherboard: step 6, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement, Motherboard: step 6, image 2 of 2
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Headphone Jack Replacement: step 7, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 7, image 2 of 2
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Headphone Jack Replacement: step 8, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 8, image 2 of 2
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Headphone Jack Replacement: step 9, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Headphone Jack Replacement: step 10, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 10, image 2 of 2
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Headphone Jack Replacement: step 11, image 1 of 3 HP 7 Plus 1302 Headphone Jack Replacement: step 11, image 2 of 3 HP 7 Plus 1302 Headphone Jack Replacement: step 11, image 3 of 3
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Headphone Jack Replacement: step 12, image 1 of 1
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Headphone Jack Replacement: step 13, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 13, image 2 of 2
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Headphone Jack Replacement: step 14, image 1 of 2 HP 7 Plus 1302 Headphone Jack Replacement: step 14, image 2 of 2
    • Pull the circuit board off.
  15. HP 7 Plus 1302 Headphone Jack Replacement, Headphone Jack: step 15, image 1 of 1
    • Desolder the six points on the headphone jack using the soldering iron.
    • Soldering iron will be hot be careful.
    • For more instructions about how to use the Soldering iron click here.
Shannon Suttles
225 Reputation
2 Guides authored
IUPUI, Team 1-4, Baechle Spring 2017 Member of IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 140
