HP Chromebook 11 G3 Charging Port Replacement
  1. HP Chromebook 11 G3 Charging Port Replacement, Keyboard Mount: step 1, image 1 of 2 HP Chromebook 11 G3 Charging Port Replacement, Keyboard Mount: step 1, image 2 of 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Charging Port Replacement: step 2, image 1 of 2 HP Chromebook 11 G3 Charging Port Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Charging Port Replacement: step 3, image 1 of 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Charging Port Replacement: step 4, image 1 of 3 HP Chromebook 11 G3 Charging Port Replacement: step 4, image 2 of 3 HP Chromebook 11 G3 Charging Port Replacement: step 4, image 3 of 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Charging Port Replacement: step 5, image 1 of 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Charging Port Replacement, Charging Port: step 6, image 1 of 1
    • Gently remove the charging port’s slide-out connector from the motherboard.
  7. HP Chromebook 11 G3 Charging Port Replacement: step 7, image 1 of 1
    • Locate the two brown clips that secure the charging port to the motherboard from both edges.
    • Remove the charging port by sliding the plastic opening tool between the charging port and one of the clips, and then prying.
  8. HP Chromebook 11 G3 Charging Port Replacement: step 8, image 1 of 1
    • Lift the charging port out of the base.
Rahul Goyal
1,369 Reputation
10 Guides authored
Cal Poly, Team S23-G3, Livingston Spring 2017 Member of Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Members
12 Guides authored
One Comment
I have a Model CB2 (also known as 11-1102) that has this same issue. Would the instructions be the same? Would the part be the same? Where did you purchase a replacement charging port?
Jim Grybowski - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 9
All Time: 2,200
