HP Chromebook 11 G4 Keyboard Replacement
  1. HP Chromebook 11 G4 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Keyboard Replacement: step 2, image 1 of 2 HP Chromebook 11 G4 Keyboard Replacement: step 2, image 2 of 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Keyboard Replacement: step 3, image 1 of 2 HP Chromebook 11 G4 Keyboard Replacement: step 3, image 2 of 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Keyboard Replacement: step 4, image 1 of 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Keyboard Replacement: step 5, image 1 of 2 HP Chromebook 11 G4 Keyboard Replacement: step 5, image 2 of 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Keyboard Replacement: step 6, image 1 of 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Keyboard Replacement: step 7, image 1 of 3 HP Chromebook 11 G4 Keyboard Replacement: step 7, image 2 of 3 HP Chromebook 11 G4 Keyboard Replacement: step 7, image 3 of 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Keyboard Replacement: step 8, image 1 of 1
    • Remove the keyboard assembly by lifting it off the laptop base.
3 other people completed this guide.
Jair Herrera
694 Reputation
4 Guides authored
Cal Poly, Team S16-G5, Banghart Winter 2018 Member of Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Members
15 Guides authored
3 Comments
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - Reply
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - Reply
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 22
All Time: 9,217
