HP Chromebook 11A G8 EE Keyboard Assembly Replacement
  1. HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 1 of 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 2 of 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: step 2, image 1 of 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: step 2, image 2 of 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: step 2, image 3 of 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: step 3, image 1 of 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: step 3, image 2 of 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
6 other people completed this guide.
Ella Portwood
684 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 2,521
