HP Chromebook 11A G8 EE Screen Replacement
  1. HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: step 1, image 1 of 2 HP Chromebook 11A G8 EE Screen Replacement, Keyboard Assembly: step 1, image 2 of 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Screen Replacement: step 2, image 1 of 3 HP Chromebook 11A G8 EE Screen Replacement: step 2, image 2 of 3 HP Chromebook 11A G8 EE Screen Replacement: step 2, image 3 of 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Screen Replacement: step 3, image 1 of 2 HP Chromebook 11A G8 EE Screen Replacement: step 3, image 2 of 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Screen Replacement, Bezel: step 4, image 1 of 1
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Screen Replacement: step 5, image 1 of 1
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Screen Replacement: step 6, image 1 of 1
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Screen Replacement: step 7, image 1 of 1
    • You are finished once the bezel is off of the device.
  8. HP Chromebook 11A G8 EE Screen Replacement, Screen: step 8, image 1 of 1
    • Remove the four 3.5 mm screws with the Phillips #0 screwdriver.
  9. HP Chromebook 11A G8 EE Screen Replacement: step 9, image 1 of 1
    • Flip the screen towards you.
  10. HP Chromebook 11A G8 EE Screen Replacement: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Once the screen is flipped down, use the tweezers to peel away the black tape holding down the connector.
  11. HP Chromebook 11A G8 EE Screen Replacement: step 11, image 1 of 1
    • Next, peel away the tan tape, using the tweezers, exposing the screen connector.
  12. HP Chromebook 11A G8 EE Screen Replacement: step 12, image 1 of 1
    • Using the tweezers, remove the connector by the latch attached to it.
  13. HP Chromebook 11A G8 EE Screen Replacement: step 13, image 1 of 1
    • Finally, pull away the screen, to remove it from the device.
8 other people completed this guide.
Kim Travers
523 Reputation
2 Guides authored
One Comment
Does IFixit Sell this screen? I am unable to source parts and this screen for these educational units by HP. I wish iFixit would also list the parts that are needed for the repairs and not just the tools they sell.
Glenn Silva - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 57
All Time: 3,207
