Introduction
This guide will show you how to replace the HP Chromebook 11A G8 EE’s Wi-Fi card. The Wi-Fi card is a built in component of your laptop. The Wi-Fi card allows allows your laptop to connect to wireless internet. The Wi-Fi card of your device may need to be replaced if your device is failing to connect to wireless internet.
On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
Using your tweezers, unplug the battery connector from the motherboard.
2 other people completed this guide.
