HP Chromebook 14 G5 Motherboard Replacement
  1. HP Chromebook 14 G5 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 Motherboard Replacement: step 2, image 1 of 1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 Motherboard Replacement: step 3, image 1 of 2 HP Chromebook 14 G5 Motherboard Replacement: step 3, image 2 of 2
    • Then you can see the motherboard marked in the yellow rectangle.
    • Unscrew the 4.1mm screws around the motherboard using the Phillips #00 screwdriver.
  4. HP Chromebook 14 G5 Motherboard Replacement: step 4, image 1 of 2 HP Chromebook 14 G5 Motherboard Replacement: step 4, image 2 of 2
    • Disconnect the two Flexible Flat Cable (FFC) from the device.
  5. HP Chromebook 14 G5 Motherboard Replacement: step 5, image 1 of 1
    • Remove the motherboard from the device.
We omitted some photos of reassembling the device. For this part, follow these instructions in reverse order.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,214
