HP Chromebook 14 G5 SD card reader Replacement
  1. HP Chromebook 14 G5 SD card reader Replacement, SD card reader: step 1, image 1 of 1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 SD card reader Replacement: step 2, image 1 of 1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 SD card reader Replacement: step 3, image 1 of 1
    • Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
  4. HP Chromebook 14 G5 SD card reader Replacement: step 4, image 1 of 1
    • Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
  5. HP Chromebook 14 G5 SD card reader Replacement: step 5, image 1 of 2 HP Chromebook 14 G5 SD card reader Replacement: step 5, image 2 of 2
    • Disconnect the Flexible Flat Cable (FFC) from the motherboard.
  6. HP Chromebook 14 G5 SD card reader Replacement: step 6, image 1 of 1
    • Remove the SD card reader the device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 321
